Apexi Induction kit ---- Advice please
Mr Windscreen
Post by Mr Windscreen »
Thanks for the pics, that really helps. :-D
I would guess your ecu would compensate for adding a cone induction kit (or 2) as its not gonna be a huge enough power change.
Remember hearing Bens for the first time after he had his done and the difference was amazing.
When I put on my HKS ones in the Rex it sounds a lot louder.
You will be addicted to the noise !!!!!
Mr Windscreen
Well I tried for 3 hrs!! this morning to fit this kit and I cannot remove the bloody standard airbox! I have unbolted the afm on top and the two retaining bolts top and bottom. How the hell do you remove the bottom afm as you cannot get to it. Have I got to take half the pipework around the airbox off to do this??? I,ve now given up and will probably have to get a garage to fit it.
No idea - I had Abbey fit it :)
Interestingly Mirage is also fitting Apexi's as we speak. Could catch up with him and see if he can help or has had the same problems.
323ian
Post by 323ian »
No need to reset your ecu so dont bother.
Mirage does not have a airbox he has cheapo filters at the moment.
Mr Windscreen
Thanks, if anyone knows how to get the airbox out let me know.
boxy
Post by boxy »
Can`t imagine it would be too hard they are usually just bolted or plastic connectors. Probably missed something really simple.
mirage
Post by mirage »
323ian wrote:No need to reset your ecu so dont bother.
HAD cheapo filters ;)
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
boxy
Post by boxy »
Have you got the skyline workshop manual as I`ve just been looking through it and it`s quite easy?
