Its been fitted probably 2 years and has a great feel to it, nice and driveable.
It has since the temperature decreased and the car has started to pull like a train, had a tendancy to slip when on full boost.
What should I do, the HP I'm producing is not huge, probably no more than 420/430, I will continue tuning until around 500 tops I think, so I want something that will cope, but remain driveable because I use it to commute in traffic. I will also fit my Fidanza Flywheel when I change it out.
Uprate the pressure plate?
Go for a 6 PUK, this surely affects the driveability??
Fit an uprated organic clutch and pressure plate?
What sort of life can I expect from the suggested alternatives???
Any comments welcome
Thanks
JC
