confused civic type R
j
Post by j »
hi can anyone advise please on best route to further mod my car?? its got AEM V2 induction snd full magnex with de-cat (215bhp ish) i use it daily and enjoy track days but not happy with her times up the strip, low 15s on bad tryes :( budget! all depends on which way is best. turbo? supercharged? or all engine but between 1k-6-7k at a push over next 6months.
jason
jason - what are the 60ft times like - is it a traction issue that is causing the lower times?
j
Post by j »
not sure of times at moment all tickets in car which is in garage having new tyres brakes service etc ready for the meet on weds :) but up to 8th was ok ish, alot of wheel hop though
dee_rz
Post by dee_rz »
hi jason first i would register on civic-typer.co.uk forum and get friendly with people on there and maybe have a chat with someone like guy at cpl racing in kent he knows his stuff on the k20.
i have owned two ctr's before going to a supra there great cars in terms of time for a fairly stock car the ctr pulls great times in my opinion remember it doesn't have bags of torque and is n/a.
i did 14.8 in a stock ctr put toyo tr1's and much improved things over the hard re040 standard after those i tried the re050's from an s2000 and found a slight improvment but toyos being best.
ending up spending 5-6k on the second ctr and had the 12th fastest fwd car in the uk it ran 13.6@107 2 years ago have a vid somewhere.
i'll be happy to talk more on this thread or via pm's with you and disclose a few more things etc my ctr had 326.6 bhp by the way thats how it did the 13.6 if you are wondering 8) will talk soon :grin:
goodap
Post by goodap »
there were a couple of civic type r's at a recent trackday at coltishall and front wheel traction did seem to be the main problem with them, sounded lovely though 8)
Yeah you cant beat the sound of a Honda Vtec !
Still reckon I will get an Integra at some point.
Obviously 'in addition' to the Rex lol
i - it may be more worthwhile if you state what you are trying to achieve, my guess is a setup for drag is going to be very different than that for the track.
Post some pics and spec of your machine up in the gallery so we can see what other mods you have, what suspension have you got ? After all 'power is nothing without control' !!
j
Post by j »
post pics ha ha i've only been using computer about 2 weeks :lol: but premiere garage in beccles took pics today after my work was done said
he was putting them on this site and this one, just standard suspension at mo but just ordered some tanabe springs and eibach rear arms and front bolts, oh and mine sounds to loud :)
dee rz
5-6k for 13.6 was hoping id be able to get abit more than that, was yours supercharged? already spoke to guy at cpl 10k full works on turbo or supercharged start at 2700 fitted, but i can get same jackson kit for 1800??
dee_rz
Post by dee_rz »
coilovers
j
Post by j »
nos? i've heard so many stories good and bad, would like it been advised not to on standered block, how much you put through was it on standard clutch? thats next on list while its of i should really get lsd and flywheel done save a few squid doing all together :)
dee_rz
Post by dee_rz »
I knew i forgot something :D i had a clutchmasters clutch and a fidanza flywheel also thats another 1k to add :D i found that the lightweight flywheel really made the fact that falling out of the power band was more likely to happen unless you lower the vtec point which i wouldn't touch unless you change cams as honda have that all where it should be unless you mod a great deal.
What year is your ctr as the facelift models had a lighter flywheel (6.5KG same clutch but has a even disrubution of holes cut in it to achieve the weight loss)than the pre face lifts (8KG) fidanza weighs 4kg i think at the top of my head at around 300bhp you need an uprated clutch as i found after lunching 2 stockers in one year i had 326.6 bhp with around 215 ft lb of torque.
Nos is fine if used and set up correctly i had a progressive controller so it was not shot in violently like a straight shot, i used 100bhp jets so 100bhp of nos from a wet kit using all safety that was built into the controller i.e window switch for set revs and lean cut facility etc so it was fairly safe i used that kit and had that power for around 1 1/2 years with no problems.
