Impreza STI prodrive edition.. for those interested.
Cheers for your replies chaps
Spec is under construcytion but heres a short rundown.
Full Hayward & Scott 3" decat system (wrapped)
Green panel filter with ram duct from bumper (replacing with CAI as maf has now maxed out )
HKS SSQV
Fuelab Adjustable FPR
Walboro 255l motorsport fuel pump
TD05 20g turbo
Big bore Hayward & Scott wrapped uppipe
Denso Iridium plugs
Custom oil catch tank
All mapping by Zak @ Mocom Racing
18" speedline turinis (not in pic)
235-40-18 Vredestein Ultracs
Tar:ox G88 front discs with 114 track pads (soon to be EBC Yellowstuff)
rear running EBC yellowstuff on OEM discs
Goodridge braided lines
Motul RBF 600 Fluid
Whiteline Springs
Whiteline Adjustable Front ARB
Whiteline adjustable Rear ARB
Whiteline HD mounting kit
Noltec Billet polybushed droplinks
Noltec rosejointed camber/caster billet topmounts
Mocom Racing custom geometry setup
Work in progress
Fully flocked dash
Custom A pillar pod
Custom steering column pod
Retrimmed STI8 steeringwhee
Defi Bf linked meters - Boost, Fuel press, oil press, oil temp, water temp and EGT
Nomad racing ACT gauge
Innovate motorsports wideband AFR
As said.. all engine/chassis development is a big work in progress as things are being indevidually tried and tested all the time.
I will post more pics as things happen :d
Thanks for looking
HKS SSQV
TD05 20g turbo
Denso Iridium plugs
Motul RBF 600 Fluid
Whiteline Springs
Work in progress
Fully flocked dash
Custom A pillar pod
Thanks for looking
I have an ST V4 TMIC off a 22B, which i will fabricate into place.frayz wrote:
All in good time my friend.. hows the new setup going?
Got an STI topmount yet?
I also have an STI V7 TMIC, although i doubt this can be squeezed in.
But i will discuss this further with Zak, when i have it in my hands!
