My 200SXs
STiMPY
My 200SXs
Post by STiMPY »
My 99 sapphire blue S14a, owned for almost 4 and a half years. Was my daily driver for 2 years until work mileage dictated that it became my weekend fun machine. The engine was rebuilt towards the end of last year by APT, and I had some suspension and brake mods done while it was there:
Spec:
ENGINE:
# Blitz Nur Spec R Exhaust
# NGK iridium spark plugs
# Walbro fuel pump
# Nismo 740cc injectors
# Nismo oil filler cap
# Nismo radiator cap
# Nismo engine mounts
# ARP main stud and nut kit
# ARP head stud and nut kit
# Cusco oil catch tank
# HKS Type S front mounted intercooler
# HKS SSQV BOV (recirculating)
# HKS cylinder liners
# Crower steel conrods
# Greddy intake plenum
# Greddy TD06 20G turbo
# Greddy external wastegate
# Greddy stainless steel tubular top mount manifold
# Greddy front pipe
# Greddy 86.5mm forged pistons
# Greddy rocker arm stoppers
# Greddy large capacity baffled sump
# Greddy bronze valve guides
# Tomei 256/256 poncams
# Tomei adjustable exhaust cam sprocket
# Tomei valve springs
# Tomei titanium valve retainers
# Trust metal head gasket
# A'Pexi Power Intake Induction Kit
# Z32 air flow meter
# Garage Defend carbon fibre cooling panel
# Koyo Radiator
# Oil cooler
ENGINE MANAGEMENT:
# A'Pexi Power FC with boost control kit and Commander
TRANSMISSION:
# OS Giken twin plate clutch with light flywheel
# B&M short shifter
# Nismo gearbox mount
# S15 Helical LSD
# SUSPENSION:
# Tein Flex coilovers
# Tein EDFC electronic control unit
# Pillow ball top mounts front and rear
# Front camber adjustable top mounts
# Cusco adjustable rear upper arms
# Cusco adjustable rear toe arms
# Tein adjustable front castor arms
# Nismo Power Brace
# Nismo front strut brace
# Nismo rear strut brace
# Whiteline front and rear adjustable anti-roll bars
# Whiteline subframe align and lock kit
# BRAKES:
# R33 GTR Brembo front and rear calipers
# R33 GTR front and rear brake discs
# Ferrodo DS2500 brake pads front and rear
# Goodridge steel braided brake hoses
# Cusco brake master cylinder stopper
Pics of the engine build can be found here :)
I'm a lazy sod, so the only pic of it that I have is this engine bay one:
The rolling road graph:
I'm now covering less work miles, so the daily hack was replaced a few months ago with a 96 indigo S14 which will be converted to LPG soon. This is standard apart from an HKS Silent Hi-Power exhaust and an A'Pexi panel filter. Nice'n shiny: :) (Bet you can't guess how many miles this one has done from this pic ;))
Welcome to the site
Lovely spec on the first one which seems reflected in the rolling road figures :o
As for the mileage on that indigo one.......................140k?
STiMPY
Post by STiMPY »
stuartstaples wrote:Welcome to the site
I was very pleased with the build on my S14a. APT did an absolutely superb job and I can't praise them enough :D
Your mileage guess is wrong by the way :)
139.5k - am i closest ? ;)
..... not that i am competitive am I stu ;)
Looks a fine car at whatever mileage - has Gary (shooter) been waving his magic wand on it?
The spec and dyno sheet from the previous one was mighty fine too - just keep going up and up that graph 8)
STiMPY
Post by STiMPY »
[quote="dynamix"]139.5k - am i closest ? ]
Stuart was closer, though you're both way off. Scott (Mr OCD from the SXOC) has detailed this one :) It'll be converted to LPG soon for cheap motoring :) Believe it or not, this one ticked over to 200K a couple of days ago. Aside from a couple of things, it's almost immaculate. My mate had the cam cover off not long after I bought it as it needed the VVT sprocket replacing, and he was amazed at the condition of the cams, saying they where absolutely spotless and unmarked. It runs sweet as a nut, and to be honest, when I test drove it (it had done 196K at that point), it was the best, tightest standard S14 I have ever driven, and that includes my S14a when I bought it on 34K miles! Under normal circumstances, I would never buy a car with mileage like that, but I knew this one's history (and it's HUGE). Nothing has been replaced engine-wise either, save for the lambda sensor a couple of years ago. It's still on the original turbo! It still pulls strongly right through the rev range :)
jonny_boy
Post by jonny_boy »
nice figures there matey ! and nice and shiny too ! Have seen Scotts work on the SXOC the FTO forum and it is excellent 8)
I'm hoping to get a s14a Touring for my next car but have yet to sit in one let alone drive one !
hope to see you around !
