Advice please
Its good to suit your injectors to do the job in hand. I run mine at 80 %. 90 % max but you can notice the differance. Also with high cycles like 90 % if the temp changes a lot and various other variables you could be in trouble.
The fuel system is one of the most important systems on the car. dont scrimp.
Scott
Scott
You can get problems controlling big injectors at idle/low RPM some people use two lots of small injectors instead323ian wrote:But is there problems with putting in an injector which is too big?
I mean if you had any doubt then would it be a bad thing to put in 1000cc injectors?
Thanks for that post.
