Oil temp/pressure gauges on Impreza STI?
BenTaylor
Post by BenTaylor »
Seeing as there seem to be a few Subaru owners on here...
My next door neighbour has a new Impreza STI and he's asked if I can give him a hand fitting Defi oil pressure and temp gauges. Should be pretty straight forward fitting the sensors using a sandwich plate between the block and oil filter and putting the gauges in a pod on top of the dash, but where's the best place to run the wires through the bulkhead?
Cheers,
Send Scoobyandscrappy a PM, he's just fitted DEFI's to his Impreza
Turbosnatch
Post by Turbosnatch »
My friend out here has 5 defi's in his scoob. He says its pretty strait forward. You shouldnt have any trouble
323ian
Post by 323ian »
Should be fine to find any rubber grommet and either make a small slit in that and feed the wires through or make a new hole and use a rubber grommet to feed them through.
Scoob owners will know may specifically though.
