Nik
Made in July 2000, it is one of the last v-specs before the v-spec 2 came out - damn, missed a standard carbon bonnet by 1 month.
NITROUS-XPRESS IC cooler with 15lb bottle boot mounted
APEXI INDUCTION KIT
APEXI TURBO TIMER
APEXI AVC-R BOOST CONTROLLER
APEXI POWER FC AND COMMANDER
HKS DOWNPIPES
HKS IC HARD PIPE KIT
HKS INTERCOOLER
HKS SPORTS CAT
HKS 680CC INJECTORS
HKS 11MM FUEL RAIL
HKS 1.2MM STEEL HEAD GASKET
HKS GT-SS TURBO'S (2nd edition)
HKS TURBO ELBOWS
HKS IRIDIUM RACING S45 SPARK PLUGS
FERODO DS2500 BRAKE PADS
GOODRIDGE FLEXIBLE BRAKE HOSES
NISMO CAT BACK EXHAUST SYSTEM
NISMO LIGHTNED FLYWHEEL
NISMO COPPERMIX CLUTCH
NISMO FULLY ADJUSTABLE R-TUNE SUSPENSION
NISMO SIDE AND REAR SKIRTS
NISMO FRONT AND SIDE REPEATERS
NISMO FOG LIGHTS
NISMO OIL CAP
NISMO RADIATOR CAP
NISMO PETROL CAP
NISMO FOOT PEDALS
NISMO CARBON PILLAR POSTS
NISMO DOOR EDGES
NISMO INTER COOLER SPRAYS
NISMO UK SPEC BUMPER VENT KIT
NISMO ORIGINAL HEADLIGHT EYEBROWS
NISMO KEVLAR TIMING BELT
NISMO FUEL PRESSURE REGULATOR
NISMO REAR ANTI-ROLL BAR 28.5MM
NISMO AFM'S
NISMO FUEL PUMP
NISMO ENGINE MOUNTS
NISMO GEARBOX MOUNTS
NISMO CLUTCH SLAVE UNIT
NISMO BRAIDED CLUTCH HOSE
NISMO WHITE FACED SPEEDO CLOCKS
N1 OIL PUMP
N1 WATER PUMP
CUSCO CATCH TANK
CUSCO RACING Y-PIPE
CUSCO MASTER CYLINDER BREAK STOPPER
CUSCO CARBON STRUT BRACE
CUSCO PILLOW MOUNTS
MOCAL GEARBOX COOLERS
MOCAL ENGINE OIL COOLERS
GREDDY ALLOY TOP RADIATOR PIPE
GREDDY MANUAL PILLAR BOOST GAUGE
GREDDY ADJUSTABLE CAM PULLIES
GREDDY/TRUST CLEAR CAM COVER
GREDDY OIL FILTER RELOCATION KIT
GREDDY FUEL PRESSURE GAUGE
GREDDY BOOST PRESSURE GAUGE
EAGLE/GOODYEAR F1'S GSD3 265 35 18
EARTHING KIT
SFS BLUE SILICON BREATHER HOSES
SAMCO BLUE TWIN TURBO HOSES
DO-LUCK CENTRE SUPPORT BAR
REAR CAMBER UPPER ADJUSTABLE ARMS
TOMEI PON CAMS TYPE A
TOMEI SUMP BAFFLE KIT
TEIN BONNET DAMPERS
DBA CROSSED CUT AND SLOTTED BRAKE DISCS (GOLD)
SPIDER PERFORMANCE FUEL COOLER
MAGNETIC OIL DRAIN PLUG
