Where can I get some from short notice tomorrow morning? :oops:
Radiator has sprung another leak (I'm not having much luck) & needs a temporary fix. Heading to the Midlands tomorrow midday so needs to be in or around Ely.
Loans of a tube would suffice as well & I'll replace when I get back.
Any ideas?
Metal Epoxy Putty
Naughty Magpie
Naughty Magpie
I don't suppose you want to put one of the BARS dog turds in to cure it temporarily then or an egg lol (out of the shell).
If you have a halfords near you somewhere they will sell Chemical Metal (by the Plastic Padding people). I fixed a large hole in the alloy sump of a V5 VW Golf a few years back and it did the job well. Cures rock hard with heat and is easy to shape, rub down.
Failing that, if you know someone nearby instead that can braze well enough it would make a permanent fix and wouldn't take very long to do.
This is the stuff. Available from most accessory shops and possibly petrol stations.
http://www.amazon.co.uk/Wynns-Radiator- ... B000297UG6
