stripped a wheel stud thread
balls :x
Are these just studs and reasonably easy to remove a single one?
(I have a stud remover)
bugger - just found it in the manual, it is a hub off thing as the studs push through
James Breadvan
Post by James Breadvan »
Can you get to the back of the hub and make enough room to push the stud out from the front?
360 Gamertag TheTrash
James Breadvan wrote:Can you get to the back of the hub and make enough room to push the stud out from the front?
nope :(
at the very least, it is:
- caliper off
- disc off
- bearing off
- push stud through
grrr
maff
Post by maff »
Dunc i used a balljoint splitter to push the studs out, if your lucky it may fit in situ.
found some instructions:
http://scoobymods.com/forums/showthread.php?t=4247
Job for tomorrow hopefully once I have got a spare stud....
Good job you found those instructions before trying a stud remover, as you can see.
If the stud's broken, OK but if it's 'stripped' are you sure? The stud thread is a lot tougher than the nut material so it may be it just needs cleaning the nut material out of the threads.
Whatever the cause, if it has stripped, replace the nut as well.
stockcar
Post by stockcar »
will have spares if you need them i should think..........
I am going to try and pick one up from the subaru stealers tomorrow and change it tomorrow evening. Failing that I will give you a shout Alyn.
IWANT1
Post by IWANT1 »
if ya need a hand let me know dunc, willows woking and iam board....
