i would like to put the sensor above cylender 3.
where would the cheapest place to get the adapter from?
thanks
ian
fitting defi oil temp sender into classic impreza.
12.29 @ 110.6 santa pod
the scoob is a JDM hoe
cool thankyou, found one on flebay, does this look like the right one?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
or
if i know the exact sizes that i need, i should be able to get one made up? hight, length, width, hole size etc
thanks
ian
or
thanks
ian
Re: fitting defi oil temp sender into classic impreza.
would that give you a true reading of oil temperature? I would have thought that the readings from there would be artificially high :?DaOne wrote:i would like to put the sensor above cylender 3.
thanks
ian
AAaaaaaaaarrrrrrrrrgggggggggggghhhhhhhhhhh!!!!!!!!!!!!!!!!! Not a start to that debate again!!!!!!!!!!!!dynamix wrote:would that give you a true reading of oil temperature? I would have thought that the readings from there would be artificially high :?DaOne wrote:i would like to put the sensor above cylender 3.
thanks
ian
Sorry, can't take shocks first thing.
There isn't one. Oil pressure is just behind the alternator.dynamix wrote:lol - where is the std oil temp sensor?
Could save money by just fitting an oil cooler. You'll need one sooner or later anyway. :-D
