I'm leaning towards a thrashed rad., drained and refilled her last night. this morning, no overheating, heater blows hot as normal.....still not putting it off. Will get something sorted. I was reading a few articles last night and these stock radiators have a good reputation of going to s*#t! We'll see, I'm trying to be an optimist here.
LOL, Bladey thanks for the moral boost!
Radiator problems in my '96 S14...
Just incase it is the rad:
http://sxoc.com/vbb/showthread.php?t=313652
Oh and when my 200 started loosing coolant it was down to the tubby water feeds, worth checking too, i just hope theyre easier to get to on the SR than they were on the CA.
Bryan when you re filled the radiator did you bleed the air out?
Is there a bleed screw on the SR20?
To lose the amount of coolant you are talking about i would be very doubtfull if you have a head gasket problem, especially if you have no smoke from the exhuast.
It sounds like you have a leak somehwhere, must be easy to see if there is a water leak from car if its parked up for a while?
- Bladerider
WHen mine had the liner moved you could drive all day at 6000rpm and not see a rise in temps or lose water,
Put it on boost above a bar and suddenly your watching the temp needle rise as quick as the revs.
Let it chill for 30 seconds and its normal again !!!
These sort of problems can be a right bollok ache !!
J.
J.
I have issues !!!
There is a bleed screw on the side, had a go at that and normal so far. Sounds like the water seals in the rad are gone! Hey, at least it's not a head gasket!323ian wrote:Bryan when you re filled the radiator did you bleed the air out?
