Machinists to tap an intercooler
no this one has a screw mount that holds the temp probe and also allows a take off for turbo boost guage.
TonyB
Post by TonyB »
umm, not sure on that duncan.
Your boost guage needs to be taken from the other side of your throttle flap, so unless you tap your plenium chamber(which would work but be a PITA) you should only plan to use it for charge temp.
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
ONLY 370bhp & 405ft/lb @ fly
12.7s 1/4 @ 109mph in the wet
R.I.P.
i will show you the bits Tony :D
TonyB
Post by TonyB »
I am sooo glad you used 'the' and not 'my' in that sentence :o
'05 Subaru WRX 300
R.I.P
'89 ST185 GT4
R.I.P.
frayz
Post by frayz »
Dunc, Zak has a boss for these :D
I have decided to go down a different route for this now with a set of Spa dual gauges. I can then use the boost/temp gauge with a k type probe and adaptor to fire a signal to a relay.
At this stage it will be used for the intercooler water spray but could equally use this to fire Cryogenic cooling or Water Injection should the waterspray not be enough to cool ACT. :)
frayz
Post by frayz »
Thats a nice idea however you will have 2 possible issues with that mate.
1) Mounting of a k-type
I assume you will just slip this under the boost hose. Thats alright i suppose but personally i dont like it. If you get a small swage fitting with it you'll be better off using that and tapping into the plenum.
2) Water storage.
As you dont have a spec C you, like me have just a 4 litre water tank,, this will empty within 5 minutes of track use IMO. The swap to a 12 litre spec C one would be nice however they dont come cheap.
Last time i tried getting one they were
