Lets talk about setups 8)
What aftermarket suspension components are you using and what caster, camber, toe are you running?
suspension setups
St Bosoe coilovers
Nismo upper and lower arms
Cusco adjustable tension rods
Tomei triangulated upper front strut brace
I'll dig out the geometry settings tomorrow.
I changed my set up for Eibach pro springs - lowered the car by about 1 - 2", increased the handling capabilities by quite a lot, not so much roll in the corners but didn't look for any cc plates as I don't think I need them on the pony :-D
www.ragingbullracing.co.uk
daxtojeiro
Front setup:
Tyres 235/45/17
Toe - Zero
Camber - 1deg negative
2 x Spax shocks, fully adjustable
Brakes - Jag XJS 4 pot calipers EBC Greenstuff
Discs - Jag XJS soon to be drilled and slotted, etc as they look cool :twisted:
Rear setup:
255/45/17
Toe - 20' toe in
Camber - 1/2deg negative
4 x Spax shocks fully adjustable
Brakes - Jag XJS 2 pot calipers in-board EBC Greenstuff
Discs - Jag XJS Standard discs cant see them so no need to replace them
Soon to replace all 6 shocks for Gaz
Phil
Tyres 235/45/17
Toe - Zero
Rear setup:
255/45/17
Toe - 20' toe in
Phil
TVR 5.0L Powered Cobra Replica
MSnS-Extra (EFI)
http://www.replica-cobra.co.uk
http://www.extraefi.co.uk for Megasquirt's
MSnS-Extra (EFI)
17x8, 225,45 front @32 PSI
17x9, 255,40 rear @32 PSI
Mazdaspeed front strut brace
Standard rear strut brace
Standard anti-roll bars
TEIN Super Street suspension, 16 click damper adjustment and height adjustable, set to hardest damper setting which is really nice
Using the Long Track set-up from Pettit Racing in the US.
Cheers,
Alex
Cheers,
Alex
Alex.. If you want a good set up speak to MAX ( reworks). He has a good set up on his car. He is a ring regular. He will tell you what settings he runs. I need to adjust mine with the change from normal bushes to rose jointed and 16" to 17" wheels.
Scott
Scott
