The mounting kit that was supplied required the bumper to be removed which I didn,t fancy doing and I wanted to remove the canards easily if I needed to. I was told about fairing bolts by another Big Power member and ordered some of Ebay during the week. These have a rubber grommet that fits in a small hole you drill in on your bumper. The grommet has a thread through it, into which you screw a small bolt which makes the rubber expand and grip in the hole. As it was a sunny morning I decided to get the tools out!
After some mock up fitting and some measuring it was time to drill some holes [-o< I now know how stuart felt when he fitted his canards, its a bit nerve racking drilling holes in your pride and joy.
Took about 2 hours in total to fit both. I had to adjust one of the mounting brackets at the front but no real problems. I also put an extra bolt through the bottom just for a bit more support.
I,m just waiting for some side splitters to come from Carbonmods (hopefully tuesday) and then when money allows probably a carbon rear diffuser.
Really pleased with how they look :-D :-D
