Hopefully get some time this weekend but probably won't have time to complete it. Will it start to attract surface rust quickly? Just from moisture in the air?stuart wrote:Make sure you paint that cage as soon as you can mate.
328i Sport track project - Cadwell June 09
- Mr Fletcher
good to see you today tommy and the car looks superb :thumb: the tube should be oiled still unless they degreased it all
the only place that it will start will be where the welds have burn't it off .
which tyres have you gone for ?
jason
jason
[SIGPIC] [/SIGPIC]
For all the current and future E36 owners, here's how SHP sorted the seat runners in my car. It's particularly tricky because you need to get the driver's seat as close to the trans tunnel as possible which required SHP to cut, reverse and reweld the trans tunnel side seat mount.
Full view of passenger side
Close up of passenger side runner closest to trans tunnel. The rearmost hole is for the harness lap belt. The forward hole is for the side mount for the seat
Trans tunnel runner welds directly to the old subframe
Door side runner required some extra work
And this is the work required at the back of the runner
These are views of the driver's side with the seat attached
Here you can see how the trans tunnel driver's side mount had to be cut in half, reversed and rewelded to ensure the seat is properly aligned with the steering and pedals
And here's some to show how the sunroof was welded in
