'91 r32 gtr
Or leg muscles that have ever seen exercise
Still extremely tempted to just buy another clutch but pointless to do so if its not the underlying problem, not to mention that there's no 2nd hand decent options at the moment and the new options areBen wrote:I only ever broke clutches- never had a problem with the master or slave - we did fit a nismo slave though to make the nismo super lighter. The OS Giken needed super human strength to use!.
It would be cheaper to low load the car to APT and have them sort it if you're prepared to spend
Lol... unfortunately not quite at the point of having a garage to do most of my work - both because i'd feel a little cheated not doing the work myself and secondly because it would mean less money to spend on the nice bits in the first place
Going to get the car jacked up tonight and have a play with the clutch slave, apparently they can leak inside the boot and wouldnt show any symptoms as it gets sucked back in when the rod retracts - already priced up a replacement so just a case of looking tonight
Whats bringing you to burford? Bit of a trek for you isnt it?
Ah fair enough
Good old Xscape
Its a series 1 iirc, although didnt know about the seatbelt tag will check that out more out of interest heh
Had a look at the slave today and noticed one thing about it - when the clutch pedal is pressed there's a squeak coming from somewhere, gearbox is still off the car so must be in the hydraulics somewhere...
Squeak noise;
R32 GTR clutch squeak - YouTube
Might just get a new clutch slave (
Squeak noise;
