I have heard the Apexi Map sensor is a plug and play job but isnt it for going over 1.2 bar ? I wasnt intending to do that to be honest. No idea where to get one either
The air temp is the one under the intake manifold isnt it ?
Yeah I think you're right 1.2 BAR is enough for any man (Tho I expect one day Chris will go over that :-D ) I heard the uprated ones update more frequently (like the uprated air temp senders) dont hold me on that tho.
I guess you wanna do it before you get the car mapped, they are easy to get to so I guess you dont need to worry for now. I thought I would say as I am pretty sure mines been uprated and your power output and boost levels will be similar to mine. This is all stuff the previous owner told me so I am not 100% I have got it right. Might be worth speaking to JD or Pip from WGT as they are the guys in the know? Sorry if I have opened a can of worms!
Apparently the sensor comes with the apexi boost controller kit which is a few hundred squid so probably won't be doing that straight away. But yep will have a word with Jaydee later on to see whether I need it for my 'poofy' under 1.2 bar
Atm the moment a mincing 0.8 BAR, this is what the wastegate spring is set to. I have got a boost controller setup but switched off. When I get the car mapped I am gonna get it mapped to 1 BAR then dial it down for the streets. I have heard boost controllers can also be used to help spool?
