Looking good - hope you get it finished George :thumb:
Good question regards to the weight, simple answer as light as it is when it's finished :roll: I have not set any bench mark at all I would like it to be the or one of the lightest in the world. It will be very interesting to see what it weighs.stuart wrote:George, that looks amazing.
I knew you had gone for those wide arches but I never imagined it would look that good. The holecutter should serve you well, I'd expect some decent weight reduction there. Any ideas what you are aiming for in that respect?
One question regarding the panels......how will you tie them to the chassis? Surely there will be a reduction in stiffness in the body and low pressure over these panels will encourage lift (same way that poly windows pull away from the door shuts at speed)
I look forward to seeing this in Scotland. Best of luck for your anticipated completion.
