Well, it took me a while and again thanks to some guidance from Pat on the gear shift and gear cut strategies within Solaris... but I finally got it sorted.
Nice mound of wiring. All I had to do was cut the wire from the AC switch and feed in the wire from the clutch wire and solder them together. Firstly I got the wrong AC input so was put right on that. :lol: There are only 140 wires to choose from in my defense
Then to amend some of the inputs and settings within Solaris to make it work.
1st->2nd gear shift worked a beaut as did 2nd->3rd and 3rd to 4th but 4th to 5th and 5th to 6th were throwing wobblies....
Some head-scratching and studying of logs showed that it couldnt really decide what gear it was in when in 5th so I had to amend the driveRatios in the ecu to get it to figure it out perfectly.
End result ... job done - flat throttle shifting is working a treat
