My94 wrx ra
Ian, who use to post on here, used to have one
:thumbs:
cheers stu :)
ok a few questions if i may please ;
  • do i need a fmic for sprinting if so are the ones on ebay any good?
  • can i fit 4 pots under the 16" rims?
  • where can i get "unbranded" black silcon hoses from ?
  • are cheap coilovers any benefit rather than standard suspension?
  • best place to get a new fuel pump from ?
With all the best intentions this will not be used sympatheticaly:)
Mr Fletcher wrote:ok a few questions if i may please ;
a) 'Need'? No. 'Want' maybe :) I know of plenty of guys that use cheap ones like Autobahn and they work well enough even if the fitting is a bit shonky sometimes
b) Yes
c) Pirtek
d) Adjustable in terms of height and stiffer spring rates
e) Walbro 255
I should stick to cleaning really :)
stockcar
Post by stockcar »
4pots will only fit under the later STi(96MY>)/UK (99MY>) style of 16" wheels, most of the legacy/forester stuff is designed around 2pots only as is early impreza stuff
Will the 4 pots fit under these wheels?
Yes :)
stockcar
Post by stockcar »
double yes..........
that is the 96? STi style wheel...........
