Just had and evening / early morning session on the engine and have just go home this is where it is at now
Providing we get the parts we need in time im hoping to have it in and running by the weekend
Got the engine on the stand and fitted the remaining cylinder head then fitted the buckets and shims followed by the cams and it brought us to this stage
Then fitted the baffle and oil pick up in the bottom end followed by the sump
Then fitted the rear part to the cam belt casing followed by the cam pulleys and fitted all new idlers. Next was to time the engine up
Crank
N/S cams
O/S cams
A genuine belt has makings on it the belt is positioned with dotted line on the crank and the 2 other lines will line up with the top markings on the intake cams on both heads if they do not line up like below you have done something wrong
Which brought it to this stage
Next was to get cam belt casings on and fit the bottom pulley
Just laid the inlet manifold on to see what it looked like
So its getting there i will keep you all updated on the next stage
