Project STi Time Attack
It was the one that some people pulled out of so I managed to grab a late entry. Personally it was the one that interested me the most..... great windy, hilly circuit that would be too far to go for just a track day for. the rest are too easy and convenient for us to do.
REALLY looking forward to it :D
Best of luck Dunk :thumb:
Good to see some sensible mods, particularly bigger squirters for reliability. The catch can will come in handy, as even your old block won't fill 2.6 litres within a few laps ;) Your testing at Cadwell will be of great interest. If you get the chance to do some comparisons between this time and October when we were there last, that would be great.
323ian
Post by 323ian »
Yes best of luck mate, bet you will become hooked after the first event you do!!
Hope you get finished in time, just dont let me do any time planning for you! :lol:
mike-payne
Post by mike-payne »
I will look with eager interest at your lap times Duncan....
However having just spent 2 hours with Andy Walsh, i have gleened a few tips for KH and he tailored my training to suit this circuit....
Well i now have an understanding and apparently a natural ability for Left foot braking and we also worked on my heel and toe techniques.
But more importantly, he thought the car drove and handled great (even if it's only running 1.0bar boost).
He then did his fast laptime of the mini circuit he sets up. put a time in of 55secs. his words are "that's a quick time...." i managed a 57secs.. not bad compared to his time...... just think what i could have done with 2.0bar boost!
Good luck with the plans and hope you do well at Knockhill.
Worbs
Post by Worbs »
Looking good mate, like the idea of the catch can drain to the sump. Will it act as like an overflow? or will it drain straight from can to sump?
On a very expensive and time consuming quest for 500/500 ;0)
It will drain straight back to the sump allowing for a small delay to drain down the hose. It will burn off any water in there quite quickly and will effectively mean that rather than the oil coming into the intake (as is the std arrangement for emissions purposes) it will get recycled and keep the engine det free without me having to drain it or worry about whether it is full (as I have to at the moment)
Tyres:
Have pretty much decided on running Yokohama A048R 235/45/17 in a medium compound. These are slightly softer than the normal 48's so wont last quite as well but should heat up quickly and be warm enough on the hot laps to make it count and try and keep up with Mike :D
Hopefully they will last a few track days so that i get a chance to see how much different they are at Snetterton.
Injectors & CAi
Date fixed for fitting of the injectors and APS kit - 28th June
Mapping will also be done to take boost up across the board.
Will also be getting two sets of maps done:
1) V-power for normal running
2) V-power plus CVL Turbo octane Booster (total of 103 octane) for fun stuff :devil:
Now that I have the necessary hardware I will be able to swap to the fun map for track days etc and swap back for times where I dont want to stick an extra
Worbs
Post by Worbs »
dynamix wrote:It will drain straight back to the sump allowing for a small delay to drain down the hose. It will burn off any water in there quite quickly and will effectively mean that rather than the oil coming into the intake (as is the std arrangement for emissions purposes) it will get recycled and keep the engine det free without me having to drain it or worry about whether it is full (as I have to at the moment)
Would a baffled sump eliminate the problem mate or just help ease it ? reason i ask is derek fitted a fully baffled sump to the engine i bought of him, and at present im working on my own catch can setup.
I no the baffle will help with oil pump cavitation (if thats the word im looking for lol) but after reading your thread was bit concerned i may suffer similar problems when finally get the car out on track.
I think a baffled sump will help the situation with oil surge or cavitation but that isnt really what is happening here.
The only problem that my current (un drained) solution causes is when the catch can fills up. It hardly catches a thing on normal road useage, just long high g corners and the money saved by not having to drain and throw away the oil will pay for the mod :D
