Spec:
ENGINE:
# Blitz Nur Spec R Exhaust
# NGK iridium spark plugs
# Walbro fuel pump
# Nismo 740cc injectors
# Nismo oil filler cap
# Nismo radiator cap
# Nismo engine mounts
# ARP main stud and nut kit
# ARP head stud and nut kit
# Cusco oil catch tank
# HKS Type S front mounted intercooler
# HKS SSQV BOV (recirculating)
# HKS cylinder liners
# Crower steel conrods
# Greddy intake plenum
# Greddy TD06 20G turbo
# Greddy external wastegate
# Greddy stainless steel tubular top mount manifold
# Greddy front pipe
# Greddy 86.5mm forged pistons
# Greddy rocker arm stoppers
# Greddy large capacity baffled sump
# Greddy bronze valve guides
# Tomei 256/256 poncams
# Tomei adjustable exhaust cam sprocket
# Tomei valve springs
# Tomei titanium valve retainers
# Trust metal head gasket
# A'Pexi Power Intake Induction Kit
# Z32 air flow meter
# Garage Defend carbon fibre cooling panel
# Koyo Radiator
# Oil cooler
ENGINE MANAGEMENT:
# A'Pexi Power FC with boost control kit and Commander
TRANSMISSION:
# OS Giken twin plate clutch with light flywheel
# B&M short shifter
# Nismo gearbox mount
# S15 Helical LSD
# SUSPENSION:
# Tein Flex coilovers
# Tein EDFC electronic control unit
# Pillow ball top mounts front and rear
# Front camber adjustable top mounts
# Cusco adjustable rear upper arms
# Cusco adjustable rear toe arms
# Tein adjustable front castor arms
# Nismo Power Brace
# Nismo front strut brace
# Nismo rear strut brace
# Whiteline front and rear adjustable anti-roll bars
# Whiteline subframe align and lock kit
# BRAKES:
# R33 GTR Brembo front and rear calipers
# R33 GTR front and rear brake discs
# Ferrodo DS2500 brake pads front and rear
# Goodridge steel braided brake hoses
# Cusco brake master cylinder stopper
Pics of the engine build can be found here
I'm a lazy sod, so the only pic of it that I have is this engine bay one:
The rolling road graph:
I'm now covering less work miles, so the daily hack was replaced a few months ago with a 96 indigo S14 which will be converted to LPG soon. This is standard apart from an HKS Silent Hi-Power exhaust and an A'Pexi panel filter. Nice'n shiny:
