Hi all,
I'm considering an STi4, with sprints, trackdaying and road use in mind. It has a recon box, done by Power Engineering 2yrs ago, with what I believe are UK ratios. I like the car a lot but am thinking the longer ratios might be less than ideal for sprints. Can anyone comment?
Engine is standard apart from decat/filter, and I envisage a remap but no major further engine tuning.
Andy
Scoob UK gear ratios a problem for sprinting?
I think the difference between UK & JDM are the diff ratios. 4.444:1 on JDM 3.9 on UK don't think the actual gear ratios are different also the drop gear ratios 1:1 on JDM 1.1:1 on UK. If the car's fitted with a UK box complete, the rear diff would need to have been replaced too.
Easiest way to tell is post up what speed it's doing at say 2K revs. If you have JDM ratios it's 22mph/Krpm in 5th for a v4 STi
Nice car btw, look forward to seeing/chasing it
Re: Scoob UK gear ratios a problem for sprinting?
Also, to answer your question. If it is UK it'll be ultra economical on the road. Sprints may not be a problem as all the circuits are different and in some it could be beneficial (fewer gear changes) but acceleration will be down, of course, although you'll have a few more BHP than a UK car. Frightening top speed, if you can pull the revs in 5th and find a long enough straight :-D You could fit lower section tyres to compensate. You won't be able to fit 15" wheels over the 4 pot calipers.Andy916 wrote:Hi all,
Andy
Don't change the ratios. Get more power 8)
The PPG has near STi ratios but as I said, I think the JDM & UK ratios are similar, just the diffs, etc that are different.
Andy, another point, unless Andy knows different, you can't remap the v3 & v4 i.e. MY97 & MY98 ecus.
Ok, at 2k revs it's doing 50mph. Funny thing is though, my old '95 JDM WRX had exactly the same ratio. Both with the same 215/40-17s on (also got the same result for 205/50-16s, as you might expect).Gerry H wrote: Easiest way to tell is post up what speed it's doing at say 2K revs. If you have JDM ratios it's 22mph/Krpm in 5th for a v4 STi
Andy
