I did Sevenoak's North Weald on Sunday & "did a Gerry"
I'll keep an eye on here for results, stories & banter.
I heard the MSA have had feedback that a few timing errors occoured last year as a result of "non regs" number marking & subsequently thier scrutineers are meant to be being more fussy this year. I ran white numbers stuck on a black car lastyear & only got questioned at Lydden & they didn't make me do anything about it they just moaned. The rule is written in the typical MSA ambiguous way :roll:blacky wrote: Bit of both, I bought a roll of magnetic sheet and cut it up so i have a set of numbers, so just pick what I need and stick it on the car. Gerry takes the more "pikey" route of printing his on A4 sheets and taping it in his windows. Either are fine really. Just looks a little more "pro" if you have proper number on the side of the car IMHO.
At North Weald Sunday they let numbers stuck in the window go, but i don't know if all events will be as leanient as this? Don't mean to scaremoneger, but the last thing you want is to fail scrutineering becasue you cna't display your numbers properly. PITA if you ask me, but iv'e gone the route of cutting squares & having numbers stuck on & then bring out wwhatever digits i need for the event.
Also they made alot more fuss about having towing points easily accesible & clearly marked up, which isn't something i've experinced from the MSA previously? So going to be working on that one.
Hope BP sprint series is a much fun as the JISC was lastyear. Good luck to you all 8)
