What are our chances of getting through the gates as we don't have a jap car :lol:
Our sponser will be there so we would appreciate it if you would all form an ordeley queue behind us down the main straight, just to makes us look good :-D Leave your cars in 2nd gear that should do it.
But then again according to the rules you can only overtake on the left :!:
Opps did i say that out loud :oops:
TA - Silverstone you ready - What a day
Well the cars back together and just a couple of small jobs to do this weekend.
Check the plugs
Change the switches for the twin electric fans. As they have stopped working.
Re-fit the undertray
Then tomorrow it's off to the dyno centre to get the boost level reset and a final check to make sure that everything is ok. (Fingers crossed)
Check the plugs
I so want to run more boost.
I drove the car over to the dyno centre this morning as i wanted to check it out and generally feel how Herbie was behaving. The car was very smooth and pulling well from very low down the rev range. I decide to check what boost we were running we usually run 14-15psi (Don't laugh). As not to risk causing any damage I decided to use about half throttle, doing this in the past would see the boost peak and hold at 15psi.
So off I went 8,10,12,14,16psi and I had only just got passed 4000rpm and it was still climbing
Oh well at least we know how the car will feel and go once we start on the upgardes
