the effective function of a thread is 1.5 x Diameter (in steel). so if its a 10mm bolt you should have 15mm of engagement.prolex-uk wrote:Had 5 mm on the fronts and there was enough thread (was told 4 or 5 turns was OK) none on rear.P20SPD wrote:Dave, did you end up running spacers for the wheels?
If you did, did you change the wheel studs for longer ones?
I have seen a lot of fresh powder coated wheels before, even have a set myself, and i have never seen anyone re coat the hub surface.
While I was waiting for the tow truck i checked out the other nuts and other front all were loose :oops: by loose i mean i could have undone em there 7 then..........rears were also looser than they should have been.
Another lesson learnt though.......
Buddy Club guys were top notch............think if I'd had had a spare set off lower ssuspension aarms to hand they'd have fitted them for me !!.
Results from Brands hatch
mike-payne
alwayzsidewayz
