This is a reputation system designed to recognise quality posts and information aswell as to promote activity.
Points are earned for:
- each 100 posts (but post whoring will mean that you get deducted points
- each 30 days on the forum
You can also be given them or have them taken away by others because of good posts or unhelpful posts.
Please use the system as it was intended and feel free to award them to any that you like.
As a side point, if a person giving reputation points has a higher "standing" than them, the points will be worth more. Conversely if the giver is of a low reputation on here they will be worth less.
I hope that is clear and that this will be of benefit as our club continues to grow.
Please note that there are different sized stars - look at different users and it will become more clear.
- 1 very small star for each point
- then when you get to 20 you get a small star
you keep getting these rounded to the nearest 20 points for each set of 20 points.
- when you hit 100 points you will get:
and then start earning those
- when you hit 500 points you will get:
- when you hit 1000 points you will get:
