I am about to do an oil and filter change and I have been given a filter relocation kit. I was just wondering if the positioning of the relocated filter is critical or can I put it wherever I want?
Does it need to be low down or can it be high up? say near the upper suspension mount?
Any views appreciated.
Nik
Oil filter relocation position?
It does't matter if its positioned high up as the oil's pumped round. I agree with Duncan about keeping the pipes short but don't worry if its not possible National Hot Rods have their oil cooler and filter in the back of the car
2008: VW1 3rd in Class
2009: VW1 3rd in Class
2011: Ginetta Challenge
Just the relocation kit. picking the oil and filter up tonight so I can do it over the weekend ready for wednesday.323ian wrote:Mine is located on the upper suspension tower and is mounted sideways.
Just make sure you use a filter with a non return valve.
Has yours got a cooler aswell or just the relocation kit?
Thats where I was thinking of mounting it, and sideways to make it less messy when I change the filter.
Thanks for the help guys
Nik
I would have thought lower the better so the pump doesn`t have to work as hard. Gravity will assist the oil flow.Pike wrote:It does't matter if its positioned high up as the oil's pumped round. I agree with Duncan about keeping the pipes short but don't worry if its not possible National Hot Rods have their oil cooler and filter in the back of the car
Nik
As Ben has already said, please speak to Jay or Gary @ APtuning before you fit this.
Cheers
Stu
Cheers
Stu
