Running a 450bhp RB20
- Spool pistons oversized
- De stressed forged rods (arrow)
- Balanced crank rods and flywheel
- Uprated oil pump crank collar
- N1 oil pump
- Mocal oil cooler and oil filter relocation kit
- Acl race bearings big ends and mains
- Arp head and rod bolts
- Baffled sump
- Steel head gasket new gasket and oil seal set (everything)
- Head ported
- Valve seats and valves knife edged
- Ported valve chambers
- Inlet and exhaust ports ported and matched to manifolds
- Tomei cams
- Hks adjustable cam pulleys
- Ported exhaust manifold
- Ku engineering inlet manifold
- 550 cc injectors
- Cr turbos custom turbo built for spec of engine (full boost at 3500rpm)
- Rb25 gear box with custom prop
- Custom 3 inch straight through exhaust system
- Screamer pipe
- Big intercooler
- Aluminium radiator
- Z32 maf and hard pipe
- Green stuff air filter
- Braided oil a water turbo pipes
- Nistune ecu mapped by mb automotive
- 350Whp with print out (420bhp)
- Gizmo boost controller
- Hydraulic handbrake
- Tein height and damper adjustable
- Extended bottom arms
- Re worked steering rack
- Strut braces front and rear
- Front and Rear camber arms
- Hicas lock out bar
- Poly bushed bottom front arms
- Welded diff
- Deep dish steering wheel
- bride bucket seats
- Takata harnesses driver and passenger
- 17x10 et 10 deep dish wheels
- Original rocket bunny spoiler
- Rivet on wide rear over fenders
- Gtr bonnet and wings
- Jun style arches
- Rear duffuser
- 12k hid kit
- Jaguar xkrs blue
- splitfire coil packs
- Recent oil, oil filter and spark pkug change.
- Front and rear track rod ends
- Tein coilovers
- Hicas lockout bar
- Poly bushed front lower arms
- Oil, oil filter and spark plugs
- Front camber arms
- Takata harnesses
Drifts nicely as well
http://m.youtube.com/watch?v=H2p2drljFMw
