And also the 0.625 cylinder is for the front and the 7.0 is for the rear I think but what side should each one go ?
Thanks jim
I don't think it matters what side unless the pedal is offset from the center of the cylinders , on mine it wouldn't make any difference what way around the cylinders are mounted as they are pedal centered. All i need is for there to be more travel for the pushrod on the front .625 cylinder which i can get by adjusting the bar . Pete200jimcone wrote:What side of the balance bar should front and rear go ?
