I don't use my car very often, I seem to be suffering from the petrol 'going off' - the symptoms being that the ECU light comes on until I'm nearly out of fuel ... once I refill the car with 'fresh petrol' within a few miles the ECU goes off and everything is fine, come back two weeks later of inuse on comes the ECU light.
The error code that I got before was
16556/P0172/000370
16556/P0172 - System Too Rich, Bank 1
Any ideas? .. is there a part I can replace?
Over sensitive sensors?
This is a similar thing to the problem Rob had; think it was down to a coil pack with his Ben, but you'd need to check with him to be sure (different symptoms but the same ECU code IIRC)
