Anyone have any experience?
Lee
Loft Conversio's?
Loft Conversio's?
- Mr Fletcher
probably not suited as a second garage option
[SIGPIC] [/SIGPIC]
- chrislandy
You don't typically need planning as it should fall under permitted development (but best to check though). You will need to do a building control submission. The amount of structural work depends on the style of roof construction you currently have. Some people are lucky and they just need to board out the space but others need steel purlins at floor level, additional bracing where you are moving ties around on the roof trusses etc...
