Mr Fletcher keenly observed that the spacers that I need to run due to the big brakes, may also only be required due to me using the wrong wheels. Fair point. I guess one way to check whether the wide boy front end is necessary is to try a set of wheels that may clear the brakes therefore running a 50mm narrower track would enable me to use standard wings, not my poverty spec rolled ones.
So, I know our e36 owning numbers are low, but does anyone have a pair of wheels I can try on the car for an hour or so? I guess by the time I have dicked around with them I'd need them for about 48 hours in total. Most of the Kumho guys run the Team Dynamics wheels, hence the reason I asked for them.
Crate of beer or several passenger laps available to the generous helper :thumb:
