Inj: 99.9% ( injector duty cycle)
Bst: 1.39mmhg (1.39 bar more or less)
Sol: 75%
Knk: 143 ( knock,det ect)
Afl: 75%
rev: 6666rpm
Thr: 72%
Anyone got any ideas? Of normally runs 1bar max, I'm guessing a small pipe has come off, can't check right now
another set of figures:
Inj: 65.9%
Bst: 1.15
Sol: 72.6%
Knk: 17
Afl: 49.2%
Rev: 4705
Thr: 55%
the thing is its flying up to silly boost with no effort, as you can see with the throttle half open its going to 1.15bar it only stopped there because i lifted off
i had for a very very long time a fairly major boost leak, that im guessing started life as a small one, when i had it RR'd (i wasnt aware at the time it may have had this leak) but the bloke commented saying it was leaning out slightly top end and made some adjustments on the SAFC...could it be he also increased the boost (it wouldn't boost above 0.9bar at the time)
if so now its all tight and ship shape the boost is now set too high
would also explain why recently a bloke in a Astra coupe turbo driving seriously up my arse commented by pulling next to me after i gave it a few beans (up to the speed limit and safely i may add) telling me how fcuking quick it was (i thought at the time he decided to pull back)
one more set:
Inj: 64.5%
Bst: 0.95
Sol: 65.1
Knk: 17
Afl: 46.5
Rev: 4444
Thr: 43.6
im liking the boost, but having an engine fail on me at the moment, is the last thing i need financially (not that ay time is really a good time)
anyone got any ideas?
ideally i would get apt to look at it, but at the mo, the car is used once a week if its lucky, becuase im currently flying up and down the country working 16+hrs a day at the moment
