for my mk2 escort,
running MBE management, I've just modded the intake & fuel lines so its fuel pressure/mixture etc and minimum work with ECU.
looking for someone local, have tried contacting APT but no reply.
cheers ,
Dave
rolling road set-up needed?
I would send Gary@APT a PM Dave. I know they are exceptionally busy at the moment so I can only imagine that they were all flat out when you called?
Christian who runs the office/admin is also a member on the forum. You could also try him via PM.
They are by far and away the people I would go to above anyone else, local or otherwise. I may be a bit biased though
James Breadvan
