No Plates
No Plates
I seem to have a knack of busting front number plates, cones usually but they don't seem to last. The last time I bought one, from the local accessory shop, they wanted to know the ins and outs of the proverbial cat's arse hole.
What's the minimum size and where can I easily get a stick on version?
MOTs due soon and I don't want to go with a broken plate or they'll think I ignored their last warning.
TIA
Garry - speak to Adam at JD signs http://www.jdsigns.net
He should be able to make a vinly one for you.
Dont know what the law is though.
they must be valid as alot of classic cars still have them - i.e. e-types.
Fast Eddy
Post by Fast Eddy »
I had sticky ones on my Pulsar and Metro, but i believe they are not legal although i was never pulled up for them. You can probably get away with them on a trailer and Classics.
Check before using sticky ones. If Ok, most Car Accessory shops do the blank backing and letters.
99 % sure sticky ones are illegal although your car being an import you can have a small one on the front, i'l find out in a min i got the info somewhere and post the size
380mm x 85 is the smallest you can have on an import i belive
That's brilliant info. Thanks everyone :D
Bubble
Post by Bubble »
Here we are
http://www.dvla.gov.uk/media/pdf/leafle ... plates.pdf
I keep a printed copy of the import size regs in my glovebox, for those special times when you have to prove that your front plate is legal :D
Geoff Boston R34GTT RB30
__________________________
Fast Eddy
Post by Fast Eddy »
So are the stick on ones ok then as the backing is reflective
Bubble
Post by Bubble »
Fast Eddy wrote:So are the stick on ones ok then as the backing is reflective
They should pass the MOT Ok at the moment. New stricter rules were brought into the MOT test a few months ago, but they were quickly dropped.
