6 point harness fitting
Stupid question as I cant find fitting instructions for the 6 point harnesses I have got.
Where should the two straps that go up between your legs be ideally attached (obviously the floor before some smart arse....)? Is there an ideal placement ?
ScoobieWRX
Post by ScoobieWRX »
I would have said either directly parallel to end of the cushion at the front of your seat a couple of inches or so under the seat at the front. I have seen a bucket seat in the past that has a slit a couple of inches in at the front of the seat for those very straps to go through. Never seen one again since though.
In a Scooby i would be inclined to attach it to the box section under the seat that runs across ways.
Gooey
Location: I own a Old Ford, probably trying to fix it somewhere
Post by Gooey »
Do what the bloke done that built my XR2 before it was stripped and just dont attach them to anything :roll:
All fitted now - I got some great spreader plates from Alyn at ASP that just meant I had to drill the floor and screw the eyebolts through and into these.
Perfect :D
Nige
Post by Nige »
Thats what I did.
Wanted to make sure the 6-point harness was properly secured to the floor. Drilled two holes.
Made spreader plate for the top, sprayed holes and plate and fitted eyelets
Used the plates I`d bought at Autosport to secure the eyebolts under the car :thumb:
Pike
Post by Pike »
Check the blue book as I think there are maxium/minimum angles in place for crutch straps.
2008: VW1 3rd in Class
2009: VW1 3rd in Class
2011: Ginetta Challenge
This is a worthwhile find. :D
I have a 6 point to go in but the instructions with it may as well be in greek :)
Didn't think to look in the Blue Book :roll:
I couldnt see any pictures in the Blue Book or anything describing the exact location of these.
Page 178 shows a 'typical' installation but no detail for crotch straps.
Pike
Post by Pike »
It used to be in the old section "E".
