How long should your pads be lasting?
James Breadvan
Post by James Breadvan »
Asking the question , because mine are down to the metal, again! After using ds2500s and being happy with the performance but not happy with the effect it had on my disks I tried some carbotech xp10s which are meant to be their trackday pads. They worked well and only faded once on the track, they did on the other hand only last less than 500 miles part of which was the day at Snetterton.
So how long are your lasting??
360 Gamertag TheTrash
My DS2500's were lasting around 3,000 miles and that included a fair amount of track work. The Brembos were never used that heavily though as I found it better to be gradual with braking..I seem to remember you are pretty heavy on yours :lol:
It may be worth talking to a specialist brake manufacturer or distributor, Like Apex Performance (plug plug) as these guys are supplying the KSport kits at great prices. Alternatively speak to either Eddy of Fast Eddys or Alyn @ ASP as these guys are both disties for various brake firms.
In my opinion, you just need better brakes. Your car is simply too quick for that set up. They performed well at Snett, but if they're only lasting 500 miles that should tell you its own story.
gary@apt
Post by gary@apt »
james prob with the temps you running the pads to i reckon you need a race pad compound i can get some prices and options
your story sounds the same as i had with the standard evo brakes
my DS2500's lasted less than 5000 miles before crumbling away and ruining my discs.
The Performance Friction pads lasted 20,000 miles throughout last year and were only changed in October (for another set).
James Breadvan
I know what you mean about better brakes Stuart, I need them to last longer rather than increase the performance but that probably will change with some better rubber on.
I'll give you a call Gary about some pads for the meantime untill I've got the dollar for a full upgrade on top of tyres,sump,steering bits,guest harness etc,etc.
It's going to be an expensive year again :grin:
stockcar
Post by stockcar »
more than likely the issue you have are far too high caliper temps or running the pads way beyond their upper ability causing the high wear rate
not personally used Carbotechs but not a big fan judging by some of the cars i have seen
is it an EVO?? if so then Performance Friction would be the one in either z-rated or 01.............
High power Civic type R Alyn
At best the DS2500 are fast road pads.
I'd still go with PF - I love them. They are great on the road and awesome on the track too in z rated format. I will try out the 01 compound soon but I am sure they will be equaling as good.
DunkRA
Post by DunkRA »
i absolutely hate my 2500`s the carry on i have trying to clean my wheels after a trackday or a long drive does my head in :evil:
I miss my scooby :(
I need to get rid of the 2500s in my APs as I agree they're crap.
Trouble is what to change to? At
