a few days ago i fitted a FMIC, it went ok, and have been driving it for a while with no problems, today i went out and had to overtake someone and i hit fuel cut (the AVC-r said i t had peaked at 1.16bar...i thought it was set to 1bar max ) it had never gone over 1bar in the past
anyway all was ok, started to take it easy just in case then at a junction i had to pull out quickly again i got fuel cut (or at least i thought it was fuel cut) now as soon as it goes into positive boost it judders and wont accelerate and feels like its firing on 3 cylinders there "appears" to be soot/black smoke coming out the exhaust
just giving the pipes at least the ones i can get to a check over for lose clips ec but everything seems fine :?
so firstly assuming the AVC-r is set to 1bar any idea's why its creeping up
and secondly does it sounds like i have a boost leak?
Mark
hmm I'm hoping this is a boost leak
in all honestly, it sounds like you need to turn the gain down on your boost controller. quite often you will boost higher with a FMIC than with a TMIC because they are just so much better at their job.
if it was a boost leak your car would be quite sluggish, sound like an aerosol can on boost and generally be a bit crap.
tweak your ebc
as for the black smoke, it sounds like one of the cylinder isnt firing, check spark plugs, HT leads, dizzle cap, but first just check the leads are fitted snugly.
tweak your ebc
Re: hmm I'm hoping this is a boost leak
Is it a scoob perhaps????......I have heard similar problems with coil packs on scoobs???Hugh Janus wrote:a few days ago i fitted a FMIC, it went ok, and have been driving it for a while with no problems, today i went out and had to overtake someone and i hit fuel cut (the AVC-r said i t had peaked at 1.16bar...i thought it was set to 1bar max ) it had never gone over 1bar in the past
Mark
Just my .002 pence worth...hope you suss it out m8
It was a sad day we left the croft.
no its a 200sx, i'll have a quick look over it later...another night spent at the barn lolLinky wrote:Is it a scoob perhaps????......I have heard similar problems with coil packs on scoobs???Hugh Janus wrote:a few days ago i fitted a FMIC, it went ok, and have been driving it for a while with no problems, today i went out and had to overtake someone and i hit fuel cut (the AVC-r said i t had peaked at 1.16bar...i thought it was set to 1bar max ) it had never gone over 1bar in the past
Mark
