E39 BMW 520i Overheating
I need help! So far we've changed the thermostat, thermostat seal, thermostat housing, water pump and seal and radiator. Car is still overheating. None of the hoses are leaking and we bled the car properly. The heater still doesn't blow hot air. Where do I go next?? Please help!
I agree...reverse flushing the heater matrix is a good idea. If you could get hold of a water system pressure tester that would tell you if you have a leak. Maybe there is still a load of air trapped in the heater matrix.
