Not a computer geek! yet!
IWANT1
Post by IWANT1 »
How do i put a link up like a clicky as i only know how to stick up the full internet file???
from the BBCode help page here:
Linking to another site
phpBB BBCode supports a number of ways of creating URIs, Uniform Resource Indicators better known as URLs.
* The first of these uses the tag; whatever you type after the = sign will cause the contents of that tag to act as a URL. For example, to link to phpBB.com you could use:
Visit phpBB!
This would generate the following link, Visit phpBB! You will notice the link opens in a new window so the user can continue browsing the forums if they wish.
* If you want the URL itself displayed as the link you can do this by simply using:
http://www.phpbb.com/
This would generate the following link: http://www.phpbb.com/
* Additionally phpBB features something called Magic Linkswhich will turn any syntatically correct URL into a link without you needing to specify any tags or even the leading [url]http://.[/url] For example typing http://www.phpbb.com into your message will automatically lead to http://www.phpbb.com being output when you view the message.
* The same thing applies equally to email addresses; you can either specify an address explicitly, like:
no.one@domain.adr
which will output no.one@domain.adr or you can just type no.one@domain.adr into your message and it will be automatically converted when you view.
As with all the BBCode tags you can wrap URLs around any of the other tags such as (see next entry), , etc. As with the formatting tags it is up to you to ensure the correct open and close order is following. For example:
[img]http://www.phpbb.com/images/phplogo.gif[/img]
is not correct which may lead to your post being deleted so take care.
IWANT1
Post by IWANT1 »
IWANT1
Post by IWANT1 »
well it works for me cheers :wink:
