Good FIA Approved Bolt in Cage - Impreza
Need something? ...ask here.
blacky
Post by blacky »
Maybe one for our traders to have a look into.
After a bolt in cage, that doesn't require the dash cutting, and is FIA Approved so I can pass Scrutineering easily at Sprints.
A wise decision I reckon....I would be interested to know costings of this.
Phatbob used to custom make them Logan - might be worth asking him :thumb:
blacky
Post by blacky »
Defo a good idea Dunc :!:
Also, so is on event insurance :wink:
Problem with Custom built ones is that they are rarely FIA approved, so its then at the decresion (spelling?) of the scrutineer at each event :!:
Think our man Alyn at ASP has to be worth a call on this one :D
could be worth a look on the http://www.rollcentre.co.uk they give certificates for there fia cages and are very reasonably priced, only problem with them is you have to wait weeks for your order to be built.
blacky
Post by blacky »
hmm, interesting, cheers for the link TK :D Might give them a call as to availablility.
Found out that ScoobyClinic are the main distributers for Safety Devices cages and a 6 point bolt in is
I've got a Safety Devices cage ready to go in soon. Managed to get a second hand one but still needed to get the weld in brackets.
blacky
Post by blacky »
Okay thanks gerry, you planning on welding yours in then??
problem is, I pretty much need to sort 1 in the next 2 weeks, as when the cars in bits its gonna be easier to install the cage!
blacky wrote:Okay thanks gerry, you planning on welding yours in then??
I need to make the decision to strip it all out and then the cage brackets can be welded in. Trouble is, I like my creature comforts too much!
blacky
Post by blacky »
Hmm, yes, I missed the fact you need to reinforce the mounting points with plates, can't you weld them under the floor skin on the outerside?
As I am planning on keeping a full interior with the cage.
Did you get your plates direct from safery devices?
blacky wrote: can't you weld them under the floor skin on the outerside?
Yes you can Blacky, I did with the Sierra. The plates came as part of the 'kit' from SD but I have no idea whether they still do as I bought mine back in 2003. If they are not included anymore they are a very simple fabrication job (for a man of your calibre) or you can buy them from someone Rally Design.
