Project STi Time Attack
I thought I would start a new project thread for my car to help me to prepare the car ready for Time Attack at the end of July up at Knockhill. If all goes to plan it should be almost ready for shakedown at Cadwell Park on the 16th July.
Issues:
1. Injector duty too high running at 95+% IDC at the moment even with 3.8 bar fuel pressure
2. Air restrictions caused by airbox
3. Oil throw issue on prolonged cornering causing catch can to fill within a few laps
4. Suspension needs to be lowered and reduction of body roll and allowing greater cornering speeds
5. Tyres ... I need some :D
6. Brakes
7. TA Specifics
Plan of Attack:
1. 800cc injectors are ready to be fitted along with adjustments to the mapping to suit and small increase of boost as we had to back it off to keep within 100% IDC. This should liberate the top end a little more where duty cycle issues really get highlighted. This will extend the available power range upwards slightly giving the option to hold a shorter gear through a section rather than short shifting prior to a corner.
Power-wise I would expect another 15-20 bhp from this in the peak region but more importantly give me IDC of 80% as a max.
2. APS 70mm inner-wing mounted induction kit arrives tomorrow and will get fitted before the injectors as it will be easier to adjust the MAF scaling first to suit this and then factor in higher flow injectors than the other way around. Aside from an increase in induction noise (which I personally dont like much) it will make the whole induction system flow better and should increase both torque and bhp figures a tad once mapped to suit :)
3. The Oil Throw issue needs solving as I do not want to be depositing oil onto the track for other competitors or for me to have a moment on. I have decided to go the whole hog this time and fit a 3 x inlet, 1 x breather and 1 drain 2.6 litre catch can from Roger Clark Motorsport. This will be aeroquipped to drain back any collected oil to the sump, thereby keeping the oil within the engine and not sprayed underneath my car :D Whereas 2.6 litres does seem excessively large, I am fed up with having to drain the catch can after half a dozen spirited laps.
The catch can does not catch hardly anything during normal road use even at high boost so can 100% be solved by this solution.
This is a photo of Bob Rawle's solution that I will be putting in place (although i will be using a banjo bolt rather than a straight feed):
4. Suspension - This is strangely a lower priority than the others but as my existing suspension seems to work ok enough as it stands, it would be great to make it better but not 100% essential if funds are limited. Shortlist at the moment is: EXE-TC and KW Variant 3.
5. Tyres - looking for a small supply of R rated, probably Yoko 048's 235/45/17 for my spare wheels (sponsors would be greatly appreciated on these ;) )
6. Brakes - not really an issue now with the PF discs and pads but will be removing the backing plates and fitting cooling ducts to ensure that they stay as good as they can be.
7. TA specifics - I will need to go through the regs to ensure that the car will pass scrutineering.... be a bloody long way to go only to be turned away for a stupid thing :)
The end power result should be in the order of:
380 bhp
420 lb/ft
Not huge figures by the levels of some here, but with torque of over 350 lb/ft from 2800 to 5500rpm it should be pretty rapid around the track 8)
RobCallow
Post by RobCallow »
Dunk looks like you have a little bit of work to do!
Have you considered having the sump modified adding a feed for the catch can return and therefore leaving the sump plug as std.
Rob
yes.
Modifying the sump would effectively do the same thing for me really but would need to lift the engine out to remove and then modify the sump. A lot more work and a lot more cost. It would be nice to get the sump baffled at some point though.... but not yet :D
Sounds like a tip top plan boss, but you missed off getting a manly clutch :)
The clutch will have to survive for the time being - there has been no indication of slippage yet and I dont do hard launches (yet).
Definitely on the future mods list though along with other expensive items .... very expensive items :o
For now, though, i just want the car to be marginally quicker, but running safer hence the injectors and catch can issues being top of the list.
Bealo
Post by Bealo »
Sounds like you have everything covered, good luck and i hope it all goes to plan.
We will find out at Cadwell I hope :)
Bealo
Post by Bealo »
Yeah looking forward to that one.........
rolty
Post by rolty »
Sounds like you've got it all planned Duncan - hope everything goes to plan. The RCM setup should certainly help matters
323ian
Post by 323ian »
Sounds like a heavy duty plan mate.
One question though mate, why did you pick the track that is furthest away!!?
Would have loved to come and cheer you on but Scotland?!
