Help please with the pc
ScoobyandScrappy
Post by ScoobyandScrappy »
Hi i need to take some pics (prob about 300) from one pc and put them on to this pc or some thing which i can down load on to when i want to? the pc is running windows 95 i've tryed a ZIP drive, FLASH drive but still no go, if any one can do it for me or tell me how to do it any help pleaseeeeeeee :? :? :? :?
250 BHP 241LB FT
You can either upload them to somewhere like photobucket.com and then they will be hosted online for you to retrieve from anywhere you like or you can save them onto a CD and then load them onto another PC like that.
About as much PC help as I can give I'm afraid.
slaphead
Post by slaphead »
Does your new PC have the capability of connecting to an IDE type drive - whenever I've needed to do this sort of thing I always found it easiest just to plug the old drive into the new PC and extract what I needed that way.
Alternatley as Stu said burn it to CD or if you have a network card in both PCs connect a crossover cable and transfer files that way.
~Mark
As Mark says - this is how I have done it in the past.
Most of the newer PC's have extra hard disk drives - you should be able to remove the hard disk from the old pc and put it in the new one. There may be little switches on it to run as a slave.
Then it will be there on your new pc as the F drive or something :thumb:
Yep, Dunk and Mark have the best plan, if your'e not happy trying that yourself i'd be happy to come round and do it .... although can't do it until one evening next week.
ScoobyandScrappy
Thanks for the help all but i might try stu's way of thinking 1st ( sounds a bit easy for me :lol: )
if i still have no joy then i might need a hand please :help:
250 BHP 241LB FT
Stu's won't work if either - you don't have a CD burner or you don't have internet access .. hence why I thought you had the problem in the first place ...
Beanpotter
Post by Beanpotter »
Don't know if you've got an ipod Leigh but if you have then you can use it as a removable drive and not just for all your Girls Aloud tracks. :lol:
Only if the version of Windows 95 is the one with USB support otherwise nope.
Beanpotter
murano3 wrote:Only if the version of Windows 95 is the one with USB support otherwise nope.
:notworthy:
I'll get me coat.
