Sierra tyre pressures?
jazzymonkey
Post by jazzymonkey »
Hi, a quick question for the Sierra boys. What are the reccomended tyre pressures for 15's and what is the best for the track?
Many thanks in advance.
JM
Recommended pressures are
Front 30lbs
Rear 33lbs
For track I would try
Front 33lbs
Rear 35lbs
Tyre pressures are one of the things that you will have to play about with to find a setting that you like.
jazzymonkey
Thanks :thumb:
Im still playing with the tyre pressure and suspension settings on my Scooby, and ita a pain in the buttocks! :(
