Small fluid leak
Mr Windscreen
Small fluid leak
Post by Mr Windscreen »
Have noticed a small fluid leak on my R32. It drips off the front cross member just below the back of the engine on the passenger side. Car drive fine and all levels are correct, doesn,t seem to be engine oil. Any idea,s??? :o
Air con?
slaphead
Post by slaphead »
Drive shaft oil seals seem to be a common one - my left hand ones leaking a bit - you would see it if you pop the wheel off.
~Mark
Mr Windscreen
Part number anyone?????
mirage
Post by mirage »
check the power steering reservoir mate, mine is leaking and it comes out in exactly the same place after it has ran down the side of the car, could also be the front of the small shaft (which is also leaking slightly on mine).
look at the main pipe at the bottom of it.
R34 Nur Engine
Tomei manifolds
Endless 6 Pots
Nismo Z-Tune Plenum
PFC
GT2860's
etc.......
