Builder Wanted - around Dereham
Need something? ...ask here.
To repair pointing and cover for a chimney on a 15th century listed house.
The house is my father in laws and needs some work doing to repair a chimney that is very high up (higher than normal even :) )
I reckon this will need a cherry-picker to get the necessary height to do it.
Any one of our builders here up for the job and able to do a good job/deal ?
Pm Buff or Kev @ TKL Dunk
I'm sure there are others but these two are the only ones that I know that are mad enough to get up there :thumb:
Lloyd@JRD
Post by Lloyd@JRD »
Kev@TKL, he's top notch :-D
323ian
Post by 323ian »
Liam (L6GSR) is also a builder.
shash1
Post by shash1 »
give us a shout and will pop over for a look
kev@tga
Post by kev@tga »
cheers guys :-D i will have a look for you dunk if you want?, what grade listed building is it? do you know what heritge mortor mix they require? thanks kev
Its a 15th Century Jacobean House - whatever grade that falls into.
Will give you and Buff a shout tomorrow to see what is possible.
