Time Attack - ESC Race Car - Alive & Kicking!! + Power G
P20SPD
Post by P20SPD »
Duncan, i am running a GT35/42, on Sunday i was running 1.5bar with a global 5 degrees removed. Basically its the same map i had last year, with 5 degrees removed, and boost lowered. I wasnt getting full boost in 4th until late 4000-5000 rpm range.
Car was approx 120 to 150hp and prob 150+ lbft down on last year.
I saw my kids for more than 5 minutes yesterday for the first in ages, christ they have grown!
Toy: 550+ Subaru Impreza Wagon
Commute: E46 M3 SMG
Tow Car/Wifes: Nissan Pathfinder
stockcar
Post by stockcar »
possibly you have too big a front bar, common fault with the subaru's is to uprate the front to "match" the uprated rear, personally leave the front as a std'ish size and then tweak the rear to suit..............
mike-payne
Post by mike-payne »
stockcar wrote:possibly you have too big a front bar, common fault with the subaru's is to uprate the front to "match" the uprated rear, personally leave the front as a std'ish size and then tweak the rear to suit..............
TBH thats what we I had before. But John at Whiteline recommneded teh setup... i may keep the 27mm nd try the 27mm on the rear so they are matched and then see if the dmaper settings can give me any better control..
Will also get Andy Walsh to drive it and see what he recommends.
stockcar
Post by stockcar »
on David's rally car we run the std STi front bar and a 24mm adjustable rear, but it is on Exe-Tc so roll is totally non-existant compared to other set-ups...........
deal direct with Whiteline (as most everything else 8) ) - so happy to help out with pricing if needs be.................
alyn
Is the gearbox done Mike?
mike-payne
dynamix wrote:Is the gearbox done Mike?
Gearbox is done... broken selector fork :D
but left to do before KH
Oil cooler to be moved..
Throttle position switch to be sorted or throttle body to stop choking up....
Adjust turbo actuator to get 2.0+bar
Map on 8's to the max....
Oh and i have to find a way to get it on the trailer :?
mike-payne
Oh and forgot.....
Sti quick rack fitted..... :-D
Underdrive pulley fitted.... :-D thanks Alyn! :thumb:
Is that with the new actuator?
Yeah, I am worrying about how to get on the trailer myself - think the front bumper will have to come off :lol:
mike-payne
dynamix wrote:Is that with the new actuator?
yeah.... i had it at donny, bit wasn't adjusted up.... plus we couldn't get teh car to run on 8's due to the choking up!
Which 8's?
